EXSlider400
Oct 02, 2014Explorer
Dadoffourgirls wrote:
The towing guide and order guide had correct information.
Your telling us that you validated towing in the Owners Manual before purchasing, and not the towing guide used online and in the dealer?
I suspect that GM informed you of this change, and now you want to make an issue since you did not truly investigate prior to purchase. Also, the GCWR was 14000. I suspect that you exceeded this if the trailer weighed 7600. So bought only on tow rating, and not GCWR.
I remember verifying the 5.3 and 3.08 last August (2013) and seeing that it was less than the 4.3 with 3.42. This was because I was going to trade for a weekend until I realized that the 4.3 V6 had better tow rating.
Before I bought the truck I looked online and in owners manual and both had higher rating at 8600. I don't know about a "Towing guide", just manufacturer specs in owners Manuel. So yes I only bought on tow rating. Then a few weeks ago I received a recall notice with the lower rating. Tow info is confusing and just read some of the post....still only a few truly understand it. I also agree and think...why would they make a V8 tow less than a v6.... so they can say their V8 gets best in class MPG....
I will have to look in door jam for the other info. but there is nothing I can do now so I will just take this as a learning experience and hopefully help another reading this.
here is the updated info in users manual:
