AH64ID
Oct 06, 2014Explorer
EXSlider400 wrote:
Here is the door sticker from 3.08
here is the 3.42
I will pull across scales next time I get a chance. I may have messed up with GVWR, but am better on the tow ratings. Depends on what scales say.
You haven't fixed anything. 1/2 tons will run out of GVWR long before GCWR is reached with a TT... So the Denali is rated the same where it counts, and is a heavier truck.. so in essence you have less useable load.
You mentioned a while ago that most people don't truly understand tow ratings, this thread should have taught you that you are one of them.
Tow ratings are fairly meaningless, unless you weigh 150lbs and carry NOTHING in the truck with you.
