tkcrawford
Jul 30, 2019Explorer
s1214 wrote:
Are the sides of the tailgate too narrow or is it just the radiused lower corners? If it's the corners, use a riser to raise the bottom above the curve.
No, it isn't just the radius on the lower corners. It is the distance between the vertical sides of the tailgate opening. My "step-up" on my Eagle Cap is exactly 60" wide but the tailgate opening on the 2017 Chev I looked at is 58-3/4". I do remember awhile back someone on this forum mentioning about this being a problem with their camper, as well. What I need to know is what years GM pickup boxes have this dimension and whether or not Ford and Ram suffer from this same issue. I know my 2004 Dodge clears the "step-up" by about 1/4" on each side. Very tight but doable.
44,071 PostsLatest Activity: Aug 23, 2026
