Campfire_Time
Jun 18, 2019Explorer
I have a couple of questions, are these temps sustained, that is for hours on end, or just at the times climbing the grades? Are you using any kind of custom grill shell or grill replacement?
If these are not sustained temps it will not hurt a thing. Thinking that it is comes from using the old Dex III fluid. Your truck has Dex VI which can withstand higher temps for short bursts far better than Dex III could.
If you are using a grill shell or grill replacement it could be impeding the air flow.
Al GMs from 2006 and up use Dex VI, a synthetic blend.
It is since is already has the auxiliary cooler
It has electric fans
I agree, with that kind of weight and towing in mountains, it would not hurt.
time2roll wrote:
I would be changing the transmission fluid to synthetic if not already done.
time2roll wrote:
Next I would be checking that radiator if it was the largest available.
time2roll wrote:
Maybe change out the fan clutch.
time2roll wrote:
Lastly I would install the extra capacity transmission cooler.
