wq93
Aug 07, 2019Explorer
Are you sure that the cooling stack is really clean? Often you get a lot of debris buildup between the condenser and radiator. The HD trucks are well known for this issue after a few years and although you don't have the additional intercooler of the diesel pickups there is still a lot of area between the condenser and the radiator for stuff to get caught greatly reducing airflow.
It won't make a huge difference, but the engine heat increase may be a little less if the added transmission cooler is plumbed in ahead of the cooler in the radiator tank because it will dump more of the transmission heat before adding it to the engine coolant.
