SamCol's avatar
SamCol
Gmc 1/2 Ton Yukon 4x4 & Nash 17k
Newbie here. I have a 07 Gmc Yukon SLT 4x4 V8 3.73 Tow Package/Tow Haul. Payload 1523# Hitch wt. 1000# with WDH. Tow Rating 7200#. FRT Axel 3600# Rear Axel 4100#. I am looking at the Nash 17k. Dry wt. approx. 3537# factory rep said about 4500# with good amount of options. Cargo capacity 2963#. GVWR 7000# Length 22' 4" approx. with hitch. It will be just me most of the time. Lot's of mountain and desert driving. . I can not imagine I would load this unit to the max. If it is 4500# dry plus 1000# cargo at 13% I'm at 715 hitch wt. That leaves me 808# for myself,fuel,wdh,misc.I know this is doable, but I don't want the white knuckle, wish I had not done this experience. Should I buy a good 1/2 ton truck? Not interested in 3/4 or 1 ton. Any advice appreciated.:?
  • Well it sounds like what u have should be good to go. Is your SUV a long wheel base? If so that would be better. Also if u have the 6 speed over the 4 that would give u overall a better towing experience as far as gearing goes. Regardless it sounds like to me ur good to go. If u ever decide to go to a new 1500 series truck, then look for one that has more payload if u ever decide to go larger in the camper dept down the road. But for what u have here, appears that u should have no issues. Good luck and enjoy camping!
  • I have a tundrA with our 26rls. 6400 empty not sure loaded prob 7200 wish. Total at scales is 13,500 and pulls with no problem. I did have to upgrade tires to E rated but D rated would probably be fine.
