kzspree320
Apr 07, 2016Explorer
MFL wrote:
The GM with 6.0 is tried and true. The 250 Ford with 6.2 has been trouble free. There should be no difference in ride on the 250s. The XLT seats are comfy. Make sure the tires are aired the same, as it will make a big difference comparing ride.
Jerry
Very true. Either should handle your 11K GVWR trailer. Make sure when comparing rides the tire pressure is the same for a true apples to apples comparison. Drop tire pressure much and it generally rides better. Any of the 250/2500 trucks should handle your load fine. Pick the one you like best and are more comfortable with. Test ride all of them. Good luck. Keith
44,056 PostsLatest Activity: May 04, 2014
