dodge_guy
Jun 08, 2014Explorer II
Another question is what size tires did you have? and what size do you have now? all the numbers say your OK, but changing tire size to larger will raise your gear ratio (numerically lower). you say you went 2 sizes larger, so your 3.42 may end up being around 3.23. 3.42 with the 6 speed is good. I would either go with gearing to match the new tires or go back to stock size tires!
Good luck!
Good luck!
44,071 PostsLatest Activity: Aug 16, 2026
