yellow_dog
Aug 07, 2022Explorer
GMC TPMS
I just watched a video showing how to set up factory TPMS for trailer on GM trucks. It says you can program (in the truck) tire pressures between 50 psi - 100 psi. My 5th wheel tires require 110 psi...
yellow dog wrote:mkirsch wrote:Grit dog wrote:yellow dog wrote:
The wheels are 16," and are required to run at 110 psi per the manufacturer. I will probably just continue to use my aftermarket TPMS on the 5th wheel if I can't set them to the correct pressure in the truck.
Silliest thing I’ve heard in a while.
You really want your TPMS to alarm you at 109 psi? 1 psi under what you think it should be?
ROFL
No, he does NOT want it setting off the alarm constantly because the tires are 10PSI over pressure.
Exactly...
