TomG2 wrote:
Looks like the first four replies are trying to convince you to go diesel. I think the GM 6.0 V-8 is good for towing 9,000 to 10,000 pounds with no problem. That should cover most travel trailer that you will be looking at.
wasn't trying to convince him, just wanted the OP to know that his short distance commute likely wouldn't be the issue he thought it would be.
The newer models with the 6 speed do seem to make nice tow rigs, much better than the 6.0 with the 4 speed.
And it does give you another 600ish lbs of payload over the diesel if you order it with the 10,000lb GVWR package.
