bikendan
Aug 15, 2013Explorer
if you'd read your Pathfinder's owner's manual, it should tell you the minimum tongue/trailer weight that requires you to use a WDH.
i can tell you right now, though, that you'll definitely need one and sway control too.
get one with built-in sway control, like the Equal-i-zer or Reese Dual-Cam.
you'll also need a brake controller.
this is all dependent on your Pathfinder having the factory tow package.
if it doesn't, all bets are off.
