Mello_Mike's avatar
Mello_Mike
Good Choice for an Off-Road, Hard-Side Truck Camper?
I've taken my camper on some pretty rough roads and trails in the 3 years I've owned it and it has the scratches on the sides and on roof vents and skylights to prove it. Except for a window valence in the cabover area, the camper has held up extremely well. But in my travels I've come to realize that I need something a bit narrower and with a lower profile, so I'm starting my search for another camper.
Now I realize that I'd be better served with a pop-up camper like an Outfitter, but the wifey doesn't like them, so we need to compromise. Guys like Jefe4x4 and C.Traveler have taken their hard-side campers on some pretty intense trails and roads over the years so it can be done with the right camper.
Here are my requirements: Short-bed, non-basement model with no-slide out; no more than 7.6-ft wide, battery compartment that can hold two batteries for boondocking; 30 gallon fresh water holding tank; wet bath; dry weight less than 2,500 lbs; lots of storage.
In looking at what's available, the Northstar Arrow U 8.5 comes the closest to meeting my requirements except the battery compartment can hold only one battery.
The Lance 865 also comes close but it appears that the battery compartment can hold only one battery. Storage also appears to be lacking.
The Lance 825 also comes close, but again the battery compartment can hold only one battery, it's too small, and it sorely lacks storage.
The Livin lite Camplite 8.5 also comes close. Being a former Airstream owner, I really like the all-aluminum build. But it, like all of Livin Lite TC'ers, appears to be a basement model (confirmation would be appreciated) and has a battery compartment large enough for only one battery.
Is there a camper out there that meets all my requirements?
  • Mike, I'm quite certain that NO Livin' Lite campers are basement models, my 10.0 isn't.
    It only has room for 1 battery, but I'm considering adding a couple more to the pickup bed wheel wells. Small waste tanks, tho'. I had 2 main requirements when I ordered mine. Light weight and all aluminum/no wood. Little storage inside. I added custom cabinets.
    Good Luck
  • Don't let the "standard" configuration on the Northstar stop you. For example, my 8.5 Adventurer only comes standard with a single propane tank. When I asked Rex if it could be built with dual tanks there wasn't a moment hesitation before he said "No problem." Likewise, they built mine with dual GRP-31 AGM batteries located next to the fresh tank in an inside cabinet. This gave me more battery options as well as moved the battery weight farther forward and lower in the camper than using the standard battery tray.
    Don't hesitate to give Northstar a call. You'll be talking to one of the owners (Rex or Rory) and both are not only great people to talk to but extremely helpful.
  • Can't help with specific models, but a comment regarding batteries. With the availability of batteries like the "Concorde Lifeline AGM" and similar products, you can put an extra battery anywhere there is physical space - no need to worry about ventilation. Most campers have a place (under the bathroom sink, in the generator compartment if you don't have a generator, bottom of a closet, etc.) where you can stow an extra sealed battery which can be wired into your electrical system. So I would not let battery compartment size totally determine your choice. Also, make sure you add at least 1 large solar panel to the roof to maximize boon-docking flexibility.
    Happy Camping!
  • joeshmoe wrote:
    The livin lite appears to be long bed specific.
    "THE 8.6 CAMPLITE TRUCK CAMPER IS SPECIFICALLY DESIGNED FOR FULL SIZE, STANDARD 8 FOOT TRUCK BEDS!
    Standards in the 8.6 include LP appliances, furnace, water heater, 3-way refer, 2 burner range, exterior LP hookup, wetbath and removeable dinette table that can easily be utilized outside the camper. Choose an optional low profile roof air conditioner to make your travels even more comfortable."
    That said, All aluminum really appeals to me. I'm sure you can find a place to add another battery if need be.
    Ooops, you're right, Joe. Meant to say Camplite 8.5. I'll correct my OP.
  • The livin lite appears to be long bed specific.
  • RoyB's avatar
    RoyB
    Explorer II
    You may have to do what I am presently doing and that is review all of those neat off-road trailers Robert Ryan keeps posting on here and steal some of those ideas for beefing up your camper to suit your needs.
    I got some great beefing up ideas for my WAR WAGON Starcraft 14RT series POPUP. I too drag my POPUP back in some exciting off the maps areas. I am also going to be using some of your ideas for solar panels on my POPUP roof too.
    I'd be in hog heaven if we still lived in the Tempe AZ area again... Thats where all of my camping off the power grid adventures all started for me back in the 60s and early 70s. It was Jeeps and utility trailers back then...
    Roy Ken
  • Northstar...look at some of the other models also.
    IIRC they will customize (dual batts) to suit...
