trail-explorer
Aug 13, 2013Explorer
jimh425 wrote:
One other note, do you have a low point drain?
Even using the low point drain to "drain the tank" requires use of the water pump.
The do have low point drains as well as a tank drain, but I can see the purpose of using the tank to pump the water out - it's much faster. Using the drain takes FOREVER (at least on the rigs I've had it did)
44,060 PostsLatest Activity: Mar 28, 2026
