ExpeditionEL's avatar
ExpeditionEL
Good Smaller - Medium Units to Check Out and Advice
I have found out on here that with the ExpeditionEL we need to stay in under or around the 6,000 pound dry weight area. I looked at a local dealer today with my wife and the selection is somewhat confusing. We are Class A and C owners and could really use some suggestions for what to look at. I have a garage that we had for the Class A DP that the TT will stay in so it will be out of the weather when not in use.
I don't want RV troubles. I am too old and life is too short. Our luck with the Newmar brand was good. Unfortunately they do not make trailers and we are tired of the Class A and C stuff....
What are some good units to look at and what cautions would you like to warn me about in construction. Do they all have rubber roofs???? I saw aluminum stud walls and laminated walls. - is delamination a problem with TTs???. Also I saw some units with a cover underneath to protect all the stuff down there that I liked... We would like to find something reliable, bulletproof and hopefully lightly used (or new) if we can so I won't care if it sits in the garage and I don't use it sometimes. Suggestions??
