Took my truck (2012 F250 Diesel) to a CAT scale today to get a true 'empty' weight. Full fuel and DEF, no driver, no cargo Gross Weight 7780 lbs Steer Axle 4700 lbs Drive Axle 3080 lbs Door s...
Your empty weight, to figure payload, should be close, but just a little heavier than the factory empty weight (door sticker payload), which is nothing more than the weight your truck left the factory, subtracted from the class 2 registration number 10,000. You likely added a few things to the truck, and full fuel.
