postmandugExplorerFeb 21, 2018Good to go?Took my truck (2012 F250 Diesel) to a CAT scale today to get a true 'empty' weight. Full fuel and DEF, no driver, no cargo Gross Weight 7780 lbs Steer Axle 4700 lbs Drive Axle 3080 lbs Door s...Show More
Grit_dogNavigatorFeb 22, 2018Yup, good to go. The truck is good for almost double the payload you’re quoting with only minor suspension mods. You’re set, as is.
Related ContentHow cold can you go?carbon Monoxide alarm going offGood bye Shell RotellaGood boon-docking RV with good ground clearance?Good Route
