postmandug
Feb 21, 2018Explorer
Good to go?
Took my truck (2012 F250 Diesel) to a CAT scale today to get a true 'empty' weight. Full fuel and DEF, no driver, no cargo Gross Weight 7780 lbs Steer Axle 4700 lbs Drive Axle 3080 lbs Door s...
harmanrk wrote:kw/00 wrote:
I got 2220 when subtracting 7780 from 10000, but the yellow sticker on the door will tell u anyway what your payload is according to the manufacturer, so I'm curios if it's different from what you got.
I would expect the yellow sticker to be slightly higher, as is it the weight of the truck as it left the factory subtracted form 10000. Its safe to assume that over the course of 6 years, the truck has picked up a bit of 'base weight', bed liner, cover, accessories, gunk in the glove box, console, under the seats, it all come off that yellow sticker number to lead to that 2220 today.
