I too was shocked at the low rated cargo capacity. I had a '91 F250 that as I recall had a curb weight of 5600lbs and a gross weight of 8800lbs giving it a cargo capacity of 3200lbs. It was gas and 2wd though. I special ordered it to haul a slide in camper and wanted maximum carrying capacity. I ended up with a bigger camper than I had intended and hauled around 4000lbs on a routine basis. Other than being top heavy it did fine. 4000lbs did not quite engage the last stage of the special order factory booster springs. It was shocking how much that truck flexed when compared with the new ones. My 2016 F150 4wd has a much more rigid frame, weighs the same, 50% more hp and bigger brakes but a GVWR of only 7200lbs.
