ScottG
Jan 14, 2020Nomad
opnspaces wrote:ScottG wrote:
I have GY Endurance tires and they are great with one exception. They suffer badly from rock mining. I've never seen a tire that is this bad but at least my tires rarely, if ever see rain or moisture that could cause internal corrosion and failure.
I discovered this when I removed them for balancing.
What do you mean by rock mining? Are you referring to rocks on the trail gouging out chunks of tread?
No, rock mining is when you remove a small rock from the tire tread and can see metal underneath. When this happens water will get in and can corrode it to the point it fails. Probably wont happen but most tires are tougher in this regard.
For what otherwise seems to be a really good tire, this one aspect is a little dissapointing.
