twodownzero
Jan 14, 2020Explorer
I highly recommend the Goodyear Endurance tires and I don't use any other ST tires on my rig.
I also recommend that you air them to 80 psi. Your trailer was designed to have the tires at 65 psi because it came with D rated tires and they max out at 65 psi. While there is nothing wrong with D rated tires if they'll carry the load, keeping heat to an absolute minimum in trailer tires is what I'd recommend. I believe you're going to get the same recommendation from Goodyear, but you may find conflict even within the same company's publications about this and they currently do publish a load/inflation chart for these tires, where I don't think they did in the past. It is my view that trailer tires should be inflated to their max psi regardless of loading. I do not do this or recommend that for regular car or truck tires, but I do it for trailer tires because I don't want them to have any chance of getting hot, and that concern far outweighs any wear or traction issues that would normally concern me enough to run lower pressures.
