JIMNLIN
Jan 14, 2020Explorer III
I would not worry about the rims, the extra 15 psi will not cause an issue even if you can't find a PSI rating on the rim.
I see advise like this on rv websites quite a bit.
Having hauled for a living and being in the road 24/7 I've seen lots of split wheels and cracked valleys in the hauling industry caused by over pressure while carrying a load usually from mis reading or failure to look for the numbers.
Tires and wheels both have a load limit and pressure limit for safety reasons. Lets be safe and follow the wheel mfg limits.
