myredracer
Oct 29, 2015Explorer II
Majja13 wrote:
Some say good some say bad.
The problem with anecdotal comments from users of different tire brands is that you will NEVER know how they treated them and the info is meaningless. How much were they run under-inflated, how often and by how much run above 65 mph, how often did they hit potholes, how often did they drove on shoulders, what was the reserve load capacity above the GVW, etc. Any brand of tire can have a failure if not treated properly. ST tires are not like LT tires and need different care.
You will never hear about users that have never had trouble. It's only the ones that have had failures that go onto forums to complain about them. The number of those that post problems are an insignificantly small sample size compared to the total number of tires in use on the roads.
