Looking at a used TV. The bed currently has a gooseneck ball in it. I'll need to have it removed to put the 5th rails in the bed. By drilling more holes in the frame for the 5th rails, will this af...
Many gooseneck and fifth wheel setups do not have holes drilled in the frame, they use existing holes as manufactured. So, while you may have multiple holes in the floor of the truck bed, there may be zero installation holes drilled thru the frame.
