MitchF150 wrote:
Hey Jeremiah,
Don't know if you tried this or not, but it's worked for me on occasions when I got a 2wd open diff vehicle stuck before.... ;)
Try applying the parking brake at the same time you are giving it some gas... Yes, this works... What happens is it slows down the spinning wheel, allowing the other wheel to get some power to it and if it does happen to have better traction than the other wheel, which is likely the case, because the wheel with LESS traction will always spin first, you might just have enough traction to get some forward momentum and get free..
Mitch
We used to do the same thing with my Dads old truck when I was younger to get the boat up some slick boat ramps.
