Galena's avatar
Galena
Grand Design 308BHTS
I realize this has probably been covered many time before, but down sizing from a Class A to a TT and wondering if a 1/2 ton new model truck can handle the Reflection 308 BHTS, 9995 lbs GVWR. Is it marginal and should I just go for a 3/4 ton? Thanks!
  • I was going to buy the Grand Design Imagine 2950RL, to tow with my 1/2 ton Chevy with Max tow package and 6.2 ltr V8. That trailer had a GVW of 8995. I really liked the trailer, but weighed everything and it turned out that was cutting it way to close for my truck. Even though on the surface it looks like my truck would handle that trailer, but at nearly 34' and 9000lbs I would have felt more comfortable with a 3/4 ton truck at least. The manufacturer claims the Imagine line is built for 1/2 tons but the two largest (2950RL included) are probably better for a 3/4 ton. I believe the Reflection series is even bigger and heavier than the Imagine line. So IMHO, I would not tow any Reflection series with a 1/2 ton.
  • Towing that TT with a 1/2 ton is like Harley guys wearing that tiny skull cap. It may look cool to other Harley guys, but to those in the know it ain't cool.
    Go 3/4 ton gas or 1 ton diesel for payload.
  • fla-gypsy wrote:
    Bob/Olallawa wrote:
    I tow its brother the Reflection 313RLTS and would not use less than a 3/4 ton. Lots of tongue weight to deal with along with the length.
    That seems like a very nice trailer. BTW, what is the actual tongue weight? 1500+?
    Yes it is tongue heavy. I load light as possible but usually have between 1,400 and 1,500 lbs of tongue weight. I do stop at the scales often. Came with 15" tires and not much cushion on them either. The tires are E rated and 75mph max on the sidewall but they don't have the weight carrying of a good 16" for sure.
    Yes without question and one with a lot of payload. Might consider a SRW 1 ton
  • You can tow it, but I bet in less than a year you'll be trading for a heftier truck.
  • I tow its brother the Reflection 313RLTS and would not use less than a 3/4 ton. Lots of tongue weight to deal with along with the length.
  • At 37 feet and 10K, you'd be silly to buy a 1/2 ton truck. Nice camper by the way.
