Fisherman
Jul 23, 2022Explorer
Issues, hahahaha. Walk around, check the outside window seals, I mean the butyl caulk between the window frame and trailer walls, ditto for the door and any storage hatches. check all the electrical plugs to make sure they work. Check on the roof for proper sealing around roof vents and anything else up there. Make sure all the hot and cold water pipe unions are tight, at the fresh water tank, city water, hot water tank and sinks, shower and toilet, most of mine were loose. Got a torque wrench, apply it to the trailer nuts before you leave with it and after 50 miles to re tighten. That's a start. Cheers. Everything else, WRITE it down on the PDI sheet.
