patch60heartsExplorerOct 23, 2013gray tank outlet drain leakWe noticed last weekend that the pipe where connects to the gray tank at the outlet end has a slight leak on our sunnybrook. Is there an easy repair like applying some sealant without disconnecting?
Related ContentAdding power outlets in slide with no wiringElectrical outlet issuesSingle black/gray drain outletHouse battery drainGray tank won't drain
