braindead0
Oct 10, 2017Explorer
Mine work pretty well, one thing I've noticed is that you can't check readings right after using the tank. Water sloshes around and wets the sensors leading to bad readings. An hour later, tank readings are good.
I wanted to go with sealevel but my gray tank is too shallow as I recall correctly they require 5 or 6 inches of flat vertical minimum... my gray is just about 4".
I flush tanks thoroughly when possible, that might help.
