trail-explorer
Oct 31, 2019Explorer II
bpounds wrote:
Yes it will use a lot of grease the first time you do it, because the factory did not fill the voids in the hub. After the first time, it will take LESS grease than if you packed by hand. It shouldn't take more than 2 tubes the first time to do all 4 hubs. Buy 3 to be safe. Not a big expense.
There is absolutely ZERO reason to totally pack a wheel hub full of grease.
Even when following the instructions on proper EZ Lube technique, you still run the risk of blowing the grease past the inner seal once you jam the hub full of grease, then your brakes are shot.
I've seen it happen. There;s a video I need to find and post.
