Huntindog
Nov 03, 2019Explorer
Ride S40T wrote:Huntindog wrote:Peter2516 wrote:Do not use a grease gun on your axles.
For EZ lube axle, what brand do you use for the wheel bearing grease.
Thank you -Peter
In order to use this zerk feature, and completely purge the old grease out (maybe) it would take almost 4 tubes of grease at each greasing.... And it would most likely get past the inner seals and onto the brakes.
That creates quite a mess... Just don't do it.
This is what I've read for a while...so I called Dexter and asked their tech dept. They said using the zerk is the preferred method for greasing the bearings each year.
I specifically asked them about grease getting past the rear seal. They had no concern as long as a hand pump is used.
Wonder why they recommend as the zerk as the primary method? It would be a liability for them if they recommended something that could be a safety hazard for their customers.
That said, there is no doubt the hand method provides more piece of mind and ensures all is well with the internals.
The printed manual states that annual disassembly and inspection is required maintainence. It is on page 84.
