Peter2516ExplorerOct 30, 2019Grease gun/ grease recommendationsFor EZ lube axle, what brand do you use for the wheel bearing grease. Thank you -Peter
campiglooExplorerOct 24, 2020The void in the hub is meant to dissipate heat. Don’t fill it with grease. Best to grease and inspect them by hand.
Related ContentGreasing the hitchhitch greaseGreaseGreasing bearings questionWheel Bearings - re-grease?
