mosseater
Oct 26, 2020Explorer II
It didn't take me long to realize packing the hub is not only expensive, but pointless. I use the zerk once a year for a pump or three, then carefully use a grease needle to shoot in between the rollers on the outer bearing. Otherwise, repack by hand or grease packer. Only takes about 2 or 3 pumps to properly pack a bearing that size. You want to fill the hub, be my guest. I repack by hand every 5 years or so. Why would anyone want to force contaminated grease from the inner bearing through the outer bearing???
