Cummins12V98
Jan 17, 2017Explorer III
"ALSO at every oil change it is required to lube the outer tie rod ends."
Have you been under your truck? There are NO outer tie rod ends that have a grease fitting. The ONLY grease fitting on the current RAM trucks is the front driveline.
I think the manual does state lubing the non existent fittings.
