brulaz
Jan 18, 2017Explorer
Cummins12V98 wrote:
"ALSO at every oil change it is required to lube the outer tie rod ends."
Have you been under your truck? There are NO outer tie rod ends that have a grease fitting. The ONLY grease fitting on the current RAM trucks is the front driveline.
I think the manual does state lubing the non existent fittings.
My manual said that about the outer tie ends as well.
The RAM tech said that only applies to the bigger trucks (over 3500?). They all use the same manual?
But that same tech also said there was no front drive shaft grease fitting soooo I take what he says with a grain of salt.
