crazyro's avatar
crazyro
Greasing bearings question
I am looking in the owner's manual for my axles (AL-KO) and a couple of things I'm unsure of. I planned on jacking up trailer to work on each wheel, but manual says it's not required (Ultrulube-equipped axles). Second thing is that it mentions using a grease gun (I was told to pack them by hand). Any thoughts, suggestions, opinions, gun options? Also, would any high temp grease be ok to use? I definitely need to work on them - a couple of the hubs are running warm.
Thank you much in advance.
  • If they are running hotter than normal, I would want to take a look inside to see how the bearings and hub looks.
  • Community Alumni's avatar
    Community Alumni
    fun w son wrote:
    I just did mine not long ago... I jacked up one at a time, pumped the grease while turning the tires... I was surprised that it took about a tube per wheel
    That would surprise me too, usually it takes about a golf ball size gob for each bearing.
  • I just did mine not long ago... I jacked up one at a time, pumped the grease while turning the tires... I was surprised that it took about a tube per wheel
