However, I will admit hand packing bearing and cleaning up brake shoes looses some of it charm when you are sitting on the ground covered with grease and brake dust and grime.
Not necessary to be "covered" with grease or brake dust. As an owner increases in skill while working on the hubs, the mess will be less.
I use an over-turned pail as a seat. It is just about the right height.
After removing the hub, the hub can be worked with on a bench to remove the inboard seal, the bearing, and clean up the hub. I usually direct compressed air on the shoes and drum, using a longer blow-down gun. That keeps brake dust off me.
The bearings can be placed in a container of cleaner and agitated to remove old grease. Typically, I wipe them down with rags, put them in a bearing packer, apply grease, and immediately install in the hub. The seal is then installed, hub mounted on spindle, outer bearing greased and installed, and the nut threaded on to hold the hub and bearings in place.
Lastly, tighten nut to preload bearings and then back off until the wheel spins freely. This last step is done with years of experience behind me. An owner may wish to use a torque wrench, instead. YMMV.
