rjstractor
Mar 26, 2016Nomad
DW-gray wrote:
I have to ask, how do you come to believe the author is biased against Ford when in fact all the chart's data comes from the manufacturer's published data?
Maybe I'm off-base, but I was referring to the statement about the rear axle ratios, as well as a statement in the article about frame flex. The rear axle ratio issue we covered at length, and the frame flex issue is basically irrelevant to towing capacity. I took that to be a bias against Ford. To be, statements like this that point out a perceived disadvantage or weakness that has no real bearing on the topic at hand indicate a bias. We see it all the time here on this forum. :)
44,068 PostsLatest Activity: Jun 05, 2026
