4x4ord
Jul 27, 2021Explorer III
SirKeats wrote:
So I have a 2016 Ram 2500 Megacab with the 6.7 Cummins. I love it. Great truck.
The problem is that the payload capacity is absolutely horrible at only 1637lbs!!
That said, is there anything that can be done to increase the payload capacity?
Thanks!
The payload capacity is kind of a meaningless number on a sticker found on the door jam of your truck .... that can't be changed. If you want to increase the capability of your truck so it can handle a 3200 lb pin weight you'll have to upgrade your rear suspension. Install a set of air bags.
