frisco_dave's avatar
frisco_dave
Grey tank ABS pipe leak
On my last camping trip, noticed a small wet spot under the trailer as we were about to pull out and leave. Turns out- a hairline crack in the grey tank ABS pipe leaving the grey tank.
The crack has gotten large enough that I believe I need to cut the pipe and try to patch with a rubber coupling, as opposed to some sort of jb weld solution. Question is- how to approach that? I'd like to cut the pipe flush with the collar, and have a rubber coupling (a Fernco coupling perhaps) go over the collar on one end, and then into the 1.5" abs pipe on the other end, but- I'm not sure what size the rubber coupling needs to be to fit over the collar...if it's even made in that size.
Or- other suggestions on how I should approach a fix?
