Excellent!! Knew you guys would come through with a lot of good ideas. Knew what I kinda wanted to do, but just am not that familiar with abs plumbing options, and youtube was really of no help for my specific issue.
@time2roll- initially had thought of using a "plastimend" type solution, but I had concerns with the length of the crack, and all the jostling that would still take place. I'd probably be right back to square 1 again in 6 mths - 1 yr.
@JBarca- you are right on!! The pipe is routed into an elbow on the outside of the pic, and- going on memory here- think that then routes into another elbow, and then into the drain dump valve. I do know that the metal "hangers" do come down from the top. Just can't remember if they wrap underneath the grey tank, and- if the grey tank is also sitting on a crossbar of the metal frame. I'll need to look next time I'm out, and if as you say- will need to work on supporting it more. And I'm right with you on the fernco and flexability- that's also why I kinda prefer this solution at least somewhere along that pipe. And- never travel with the grey/black tanks full. Always dump before we leave. I do, however, travel with about 1/4 tank of freshwater, so that we can effectively have use of water if needed.
After more research around the fernco and sizes, learned you have "pipe" inputs and "hub" inputs, and this may do the trick- one end fits a 1 1/2" "hub" (this would be what I call the collar), and the other end fits a 1 1/2" pipe:
HomeDepot Fernco 1 1/2"Here was the quick video that turned the light bulb on for me around "oh- they also have "hub" ends and "pipe" ends for fernco". Some of you know this already. Again...I'm a noob for abs plumbing and what all the different options are :-)
The Hub and Pipe Concept for Fernco@mobeewan- holy cow dude- you see my city, then go the extra mile of looking up local home depot/lowes to see what's in stock- love it!! Didn't even know there was such a thing as the socket saver- so- this is fantastic! If I cut the pipe, and the fernco doesn't fit, and/or I learn more once I cut it and can peer into the hole, the socket saver is a great fallback option and would, on paper, seem like a perfect solution. If this thing works, I think the ideal solution may be to fit another pipe into the grey tank opening, then use a rubber coupling to attach to the rest of the pipe run before the elbow. This way, it does exactly what JBarca said- gives that pipe run some movement flexibility instead of being extra rigid.
@ssthrd- will look into. Could be a very viable option also.
Again- thanks all. Gives me some definite concrete options to go on. More than I had when I posted.
