DE88ROX
May 28, 2013Explorer
grey water tank capacity
Just got back from our 2nd trip with our 2012 Starcraft Autumn Ridge 235fb.
Last year was our first season out with the new TT. (obviously) and have never filled the grey tank on a long 4 day 3 night w/e.
This w/e there were a total of 4 showers. (very conservative, navy style I think its called) and we did dishes twice being careful not to let the water run. On our last night the gauges read that the grey was full. It just baffles me that this 32½ gallon tank could get so full so fast. Memorial day last year we used the camper facilities solely for all our needs and never came close to filling the grey tank.
I did replace the sensors (horst miracle probes) in both black and grey tanks prior to the this trip, so Im pretty sure i was getting accurate readings.
Upon dumping and soon as I started to empty the grey tank, I went inside and I periodically hit the the grey tank buttons and it showed less and less full as the tank was emptying just to rule out a "stuck" sensor. After dumping and rinsing out the black tank the gauges all read 'Empty' just like they should.
I asked the wife about her water usage in the shower and she said she rinsed down, water off, lather up, water on. rinse off.
I don't know just kind of confused since last year over the 4th of July week when temps were in the triple digits we used our TT shower quite a bit just because we also had the air going as well and only dumped once after about 7 days and once again a week later when we checked out.
Normally on long w/e I don't even worry about filling the tanks, so this trip really has me baffled.
When I replaced the sensors I only did one at a time as to make sure I put the right wire on the right sensors.
Baffled to say the least!:h
