ryanhousley's avatar
ryanhousley
Grey water use help
RV Newbie here! We just bought a jayco jayflight 17' trailer and need to use it in the blue ridge mtns during the winter. As I understand, the issue with pipe freezing is having water in them. Is it possible to fill the water tank when we need to use it, use the sink/shower/toilet, then drain immediately after? We have septic hookup. Would that keep the lines from freezing? Tks!!
  • Someone with actual experience in really cold temps should come along with help. There are a lot of RVers who use their rigs across the northern states and even Alaska in the winter. It can be done. But I can’t tell you how they do it. Nor tell you you can’t.
  • it ain,t worth the risk, a frozen line behind a wall could cost 5figures to fix.
  • Without blowing the lines, you will never get enough water out. If much below freezing temp, lines will freeze, if just draining the low point lines.
    Jerry
  • Draining all the lines every time you use the water would not be practical or easy. How cold will your trip be? Most newer RVs have at least some type of passive air flow from the furnace to keep the pipes from freezing if it' not too far below 32F, and you can use a light bulb in the wet bay to keep the pump from freezing. A lot of it really depends on your particular RV. Most TT's are 2 season, maybe 3. Very few are truly 4 season. Without some serious modification and a LOT of propane, you might not have a lot of luck.
    Also, your post might get more attention in the travel trailer forum instead of Class A.
