GrandpaKip wrote:
While you are doing what everybody said above, also go get a surge protector with the diagnostic lights for ground faults, reverse polarity, etc.. Before I ever hook up to anybody's box, I check it for being correct. Haven't had a bad one like you, but 30 amps can put a real hurting on you.
Good luck and let us know what happens.
We are only set up for a 30 amp as 50 amp would burn me to the ground wouldn't it? The box has a 50amp,30 amp, and a 20 amp for trailers.
Susan, Mistyblue, Shana, Tommy the terror
04 Salem 37',
Pulled by a 90 Dodge Ram Diesel
