gettinmykxs wrote:
GrandpaKip wrote:
While you are doing what everybody said above, also go get a surge protector with the diagnostic lights for ground faults, reverse polarity, etc.. Before I ever hook up to anybody's box, I check it for being correct. Haven't had a bad one like you, but 30 amps can put a real hurting on you.
Good luck and let us know what happens.
We are only set up for a 30 amp as 50 amp would burn me to the ground wouldn't it? The box has a 50amp,30 amp, and a 20 amp for trailers.
Susan, Mistyblue, Shana, Tommy the terror
04 Salem 37',
Pulled by a 90 Dodge Ram Diesel
I was talking about a piece of hardware that you plug into the campground pedestal, between the pedestal and your camper. This should be part of every camper. If you go to the fount of all knowledge ( Google ), put in RV surge protector, you will find all sorts of info.
Good luck.
