smkettner wrote:
Any hardware store has it.
Use a 15/30 adapter to plug in.
To help the cause, this is what I do at every campsite before plugging in
And once you test the power post, if it comes up 2 yellow lights OK, then go inside the camper and plug it in one of the outlets inside to test the camper.
An electrician with a volt/ohm meter can sort out your problem real quick if it is the camper.
As was said, there is still a problem. I cannot understand why the guy you had come out told you what he did. That goes agasint so many things in the electrician trade. I'm still shaking my head....
Best of luck to you.
John
