HMS_Beagle
Nov 13, 2022Explorer II
I had a mid nineties 9.5, it weighed 2800 lbs on real scales though the door decal said 2100. It also depends on whether a 2500 or 1500 series model.
You can't just "peel back the skins" on a molded fiberglass camper. You have to sawsall a significant piece of the underside off, then relaminate it and repair whatever damage you've done to the furniture. The wide part goes all the way up to the wheel wells and has stuff in it, that's why the make it wide.
I bought a Dodge in 94 that had a bit narrower tailgate than the Ford or Chevy at the time, and a Bigfoot wouldn't fit. The solution proposed was to widen the tailgate, basically by reducing the width of the reinforcing at the end of the box. Apparently it was a thing with early Dodges, I contacted a couple of body shops that said they had done it.
