RinconVTR
Jun 15, 2013Explorer
Quietgiant wrote:
I have pix but working from a 1st gen iPad up in the woods & don't know how to attach the photos.
Not wrong size tires (per manual) these are the original tires and wheels from the factory.
Barney and Dtaylor's comment of shifting the axle sounds like a good fix but, would that change the way the trailer tracts?
Thanks for your input.
If its shifting, that's an easy fix and will be obvious when looking at the area surrounding the u bolts. You'll see evidence of the axle moving with marks on the axle. Odds of this are slim, but possible. The quick fix is to tighten the u bolts. And checking they are tight will also confirm this is, or is not, part or all of of the root cause.
44,068 PostsLatest Activity: Jun 21, 2026
