justALnow's avatar
justALnow
Gulfstream Vintage Cruiser 19ERD - NO egress windows!
Less than a year ago when I bought my 2018 Vintage Cruiser 19ERD, I was surprised to see that it didn't have any sort of egress window in the front bedroom. Having traded from a larger trailer, I thought ... Well, maybe it's not required on a smaller trailer.
We recently took on this line of trailers here at Camping World and when our initial shipment of Vintage Cruisers arrived I noticed that ALL the 2019's have egress windows, including the 19ERD. I know this floor plan is also duplicated in the Vista Cruiser and I'm wondering if anyone else has dealt with this issue or knows of any recall that might be in effect to have these windows installed?
Just this morning I sent an email to Gulfstream and will talk to our warranty person here.
  • My 2010 Dutchmen has an exit on the passenger side bedroom window. It also has one a few feet away over the couch/bed.
  • Update - Brought the camper in to work last week and they ordered new windows to be replaced under warranty. Just waiting on the windows . . .
  • myredracer wrote:
    Exit windows in RVs are covered by NFPA 1192. This standard establishes fire and life safety criteria for recreational vehicles to provide protection from loss of life from fire and explosions.
    I haven't read through it in a while. Not sure on how many exit windows are required, where or what dimensions or other details. You might do some googling and look for a free copy you can read.
    Our TT has a bedroom separated by a solid door. Even though it has an exterior door in the bedroom, it has an exit window in addition to the one in the kitchen/living area.
    You should have at least one exit window and if the bedroom has a screen or curtain, it might be that an exit window isn't required in the bedroom or perhaps if it is within a certain distance from the first one isn't required. Our 1st TT was a 200 footer and had one exit window which was in the bedroom.
    If it's not code compliant, you shouldn't have any issues getting the issue taken care of. If it doesn't comply, it might help to have the code clause(s) in hand that you can show to the dealer and/or manufacturer.
    That would be one LONG trailer . . . LOL!
  • Exit windows in RVs are covered by NFPA 1192. This standard establishes fire and life safety criteria for recreational vehicles to provide protection from loss of life from fire and explosions.
  • Is there supposed to be an emergency exit window in each sleeping space?
    I saw a video presentation on my 2019 TT showing all emergency exit windows on the left side. I have one by the master bed, but a same size slider by the convertible dinette and the upper bunk (lower bunk has a outside storage access door). The siding windows are fine WHEN ITS NOT RAINING. The sliding window over the sink is protected by the awning.
  • justALnow wrote:
    Looks like there is supposed to be one behind the off-door side of the dinette, as well. Mine are all the same windows with the bottom half hinged.
    Sounds like a Friday afternoon mistake, I would think the trailer manufacturer isn't going to give you a lot of flak about having it fixed since it's a serious safety issue and they're not following code without the emergency exit. Forest River had a recent recall for the same issue, going back 2 model years so the age of the trailer shouldn't matter.
  • Looks like there is supposed to be one behind the off-door side of the dinette, as well. Mine are all the same windows with the bottom half hinged.
  • afidel wrote:
    Your driver side window isn't an emergency egress type with a red handle at the bottom? This listing shows a 2018 with the emergency window on the driver side of the bedroom. If you don't have a red handle window there I would definitely think it's a major factory screwup and should be remedied without complaint from the manufacturer as they're looking at a massive lawsuit should you have an issue!
    Nope. None are egress windows and none are marked EXIT.
  • Your driver side window isn't an emergency egress type with a red handle at the bottom? This listing shows a 2018 with the emergency window on the driver side of the bedroom. If you don't have a red handle window there I would definitely think it's a major factory screwup and should be remedied without complaint from the manufacturer as they're looking at a massive lawsuit should you have an issue!
