Scottam's avatar
Scottam
Gutter extensions
I have 2014 233s Shamrock and I am thinking of covering it this coming weekend. I wondering if the gutter extensions will cut through the cover, and if so what suggestions are there to keep that from happening. I don't think that they are removable. Thanks in advance for any helpful answers.
  • Interesting, I don't think my gutter extensions come off. This said my 8 year old adco cover is in the twilight of its life (same cover used on my previous TT) so my extensions already stick through the ripped corners of the cover.
    There is a positive side to having 4 rips on the corners of the rv cover... makes a nice guide for putting on the cover... ;)
    Mike
  • You can also use a tennis ball. Cut a slit in the ball and slide in to the gutter extension. Use caution when ever you add or remove your cover, they seem to snag on anything and everything.
  • I recently replaced a broken one on mine. They went on with one screw and some caulk, just slipped under the gutter.
  • I wrap some foam pipe insulation over the extensions. No rips in the cover yet!
