Good day!!! The D.W. would like me to hook up an H.D. antenna to our house using a travel trailer antenna. is this is possible, or will this work? I am trying not to run a cable from the existing...
There is no such thing as a HD antenna. Antennas are designed for a specific frequency range and do not know the difference between analog or digital or high or low definition. At your house you are better off with the standard mast mounted array type antenna. Since all high gain antenna are directional you may also want a rotator unless all the stations in your area are in the same general direction from your home.
